Thanks!
Matchstick ROM ported to original MK808B [Firefox OS]
Originally posted by BalintBanyasz View PostPrahjister reported WiFi working on MK808 with the MK808B ROM so I'm not sure whether you need this, but here is the download link for the MK808 port:
matchstick-flingone-b2g2.0-201409281739-mk808.img.7z
Hopefully, this one one solves the previous connection problems.
Originally posted by NigelX View PostCan you check to see if you can 'fling' from the Twitch streaming app?
Thanks!
Originally posted by rodrigoswz View PostDon't boot here. It is only in bootlogo "Google TV"
You could also try the MK808B ROM.
the firefox addon-on tells a lot. It is communicating on port 8881. I think it sends clear text commands to that port. If i can get it to work i will make a small app to configure it. The weird thing it didn't show up in my port scan. Been busy at work so i haven't been able to spend much time on this.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View Postthe firefox addon-on tells a lot. It is communicating on port 8881. I think it sends clear text commands to that port. If i can get it to work i will make a small app to configure it. The weird thing it didn't show up in my port scan. Been busy at work so i haven't been able to spend much time on this.
It looks like the main Matchstick screen is actually a webapp acting as homescreen. I think that it would be possible to convert the Matchstick ROM into a full-featured Firefox OS by installing the default homescreen app from Firefox OS and changing the homescreen app in options.
BTW there is a new RK3066-based development board featuring Firefox OS under development.
Originally posted by BalintBanyasz View PostI was able to install/run apps using the Firefox App Manager through ADB. Here is the official guide to set it up and here are some web apps to test. You can also edit the system settings and manage the running apps.
BTW there is a new RK3066-based development board featuring Firefox OS under development.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
yes , it's MK808B :
I see
on my tv :the google tv , the firefox anim ; the based on mozila technologie and finaly the setup picture .
on my pc or android : the spot wifi MachStick0808 (or an other number )
I could connect my pc or android to this spot .
but after nothing; and i can't make the configuration for the MachtStick and connect it to my box adsl.
Originally posted by samarc View Postyes , it's MK808B :
I see
There are currently 2822 users online. 6 members and 2816 guests.
