T-R42 itself off...
    T-R42 itself off...
    Hello! I bought a T-R42, chip B351V_3.2.
    Device itself off when there is load on the processor. I can not even pass the test Antutu, when testing the processor unit itself is turned off.
    Just intermittently disconnected himself USB port and Micro SD card.
    Firmware tried to change, the power supply using the D-Link 5V 3A.
    Help please.
    The T-R42 B351 v3.2 boards are bad. I have one that turns off when there's too much CPU load, it can't even watch 720p streams on XBMC without turning off. There are no custom firmwares for this board, you and everyone else with the v3.2 board is out of luck. Contact whomever sold you the box and either get an exchange or refund.
