1 - even after repeated flash the rom 2.1a CVM after the flash I have two unused icons on main desktop so there are uploaded two apps that do not know what;
2 - at the end of each flash as the tablet is locked and you are forced to reset it 1 or 2 times to stabilize the system;
3 - the system no longer recognizes the original chip and the info on the tablet (which it calls "phone") indicate a model number
GP-P7510 that I have found does not properly load resolution graphics in some apps or games;
4 - the pen ARCHOS 9G 3G Stick works;
5 - does not work the bluetooth with the USB adapter;
6 - significant gain of memory that allows you to install many more apps;
7 - in games like "Labyrinth" I have the impression of being in control of the X - Y reversed, but I still need further investigation.
At the moment I do not know if Bob will take the time to make a 2.2a for this tablet, or if there are many requests in this regard and it is likely that this will be a bit "unfinished", at the same time take the opportunity to thank Bob for the work he has done.
