MXIII / MX3 1GB with AP6181 - Firmware (FW)
    Originally posted by piperider View Post
    ... need to reformat ...
    You mean your PC? Maybe use a w7 (or better a xp) on a usb-pen-drive and boot you pc with it...
    RK3288 Devices
    - Overview BOX (LINK !)
      it would be 1000% easier if I had it in zip format I see these files in zip or img format all the time so im figuring it cant be that hard to do or it might be out there somewheres
        M82_109k4_1gddr_ap6181_sdcard->
        Here:http://pan.baidu.com/s/1hq9WNGC
        Password:yex8
        Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
          Password:yex8
          Thanks a Million
            Could you please edit the thread Title:
            [Edit Post] -> [Go Advanced] -> 'Title:'
            at post #1 to something like this:
            thanks
            RK3288 Devices
              thanks
              sorry I missed this anyway its done now thanks again
                What about the 1GB with the RTL871x Wifi
                Sorry, for sidetracking the thread, but anyone could create a custom rom for the older 1GB version? Last time I've asked I found out no one really care, but as the RTL871x is a common chip will it be possible to add the driver for it? While I am working with Unix I do not dare to risk of bricking my precious little box
                Thanks in advance, even if the answer is negative.
                  the older 1g version is easy to find its at beelink
                    Guys i have an mx3 and came wit 109 fw by oman .. its is stuck at boot ... mbox logo .. any idea how i can solve this .. i recieved the box 5 days ago from geekbuying . So im assuming its the newer batch ...
                      Thanks for the reply
                      I thought more about custom roms, as I would like to get all the nice features Finless and others put into this boxes.
                      Keep up the good work!
                        Re: MXIII / MX3 1GB with AP6181 - Firmware (FW)
                        Password:yex8
                        Hi i cannton download this version .. On every comouter it goes to 60 oercent and fails .. Can someone please help me ? Maybe a mirror ?
                        Thanks a Million
                        Sent from my LG-V500
                          Thanks a Million
                          I cannot manage to download that link .. It keep droping out .. Anyway you can share it ?
                            Mirror
                            Leider konnte Ihre hochgeladene Datei nicht gefunden werden. Laden Sie die Datei neu hoch.
                            ONLY use the small [Download] button in the middle of the screen
                            => Click image for larger version
                            RK3288 Devices
                              Thabks a lot man
                              Sent from my GT-I9505 using Tapatalk
                                Mirror
                                => [ATTACH=CONFIG]8512[/ATTACH]
                                Hey do you have e download link for the img also??? my dl time out. andt i dont have a spare sd card (that i can find :-( anyway)
