Probox2 EX - Designed for Video & Gaming
Powered by Amlogic S802-H Cortex A9 Quadcore processor with latest Android 4.4 Kitkat OS that make Probox2 EX to be a Extreme Media Player (4K Media Player + Android TV Box). That means you can watch 4K / 1080P movies and virtually do all what a tablet and smartphone can do : check your mails, navigate on internet, watch streaming videos, listen music, playing games... and much more. You can even create or use an existing Google account to synchronize contacts, mails, download applications and games from Google Play Store. All you need is a HDMI compatible TV !
Plus, with the USB host ports, you can plug any flashdrive, mouse, keyboard and webcam. With Probox2 Remote+ (included) you can easily browse your Media Player and play games. So, what are you waiting for ? Get your own Probox2 and enjoy an amazing multimedia experience !
PROBOX2 Remote+
- To maximaze the best user experience, PROBOX2 EX comes bundled with Remote+ under a limited pre-sale period (Worth $32). Remote+ is an unique tailor-made media remote controller with Air mouse function, Gyroscope, Gaming pad, builtin microphone and directional pad for easy navigation in media applications like the XBMC.
PROBOX2 EX Specifications
CPU | Amlogic S802-H Quad Core Cortex A9 CPU, up to 2Ghz |
GPU | Octo Core Mali-450 GPU, up to 600Mhz |
Memory / Storage | 2GB DDR3 / 16GB eMMC |
Wireless Connectivity | 802.11n Dual Band WIFI (2.4Ghz / 5.8Ghz), Bluetooth 4.0 |
OS | Android KitKat 4.4 |
Video Output | HDMI 1.4b, up to 4K** @ 30fps, Support HDMI-CEC |
Audio Output | Via HDMI 1.4b, optical SPDIF |
Power | DC 5V 2A adapter (CE, FCC, CCC Certified) |
Peripheral Interface | RJ-45 Ethernet Port (10/100Mbps), USB 2.0 Port x 2, OTG Port, TF Card Reader, AV Port, IR Sensor (Remote included) |
Packing Included | Probox2 EX, Probox2 Remote+, Power Adapter, Backup IR Remote, Dual-Band Antenna, AV Cable, HDMI v1.4b Cable, USB Cable, User Manual |
Dimensions / Weight | 115mm * 115mm * 26mm / 200g |
Note:** For HDMI output, it will auto detect the output mode (for example, if your TV comes with 4K output then you can select, otherwise it cannot be selected.)1. The built-in Miracast feature (under Streaming) is not compatible with Samsung or Sony devices, both brands are incompatible with PROBOX2 EX.
2. From Android 4.4 KitKat OS, Google have dropped all support for Adobe Flash Player. PROBOX2 EX does not natively support Adobe Flash Player.
3. All product specifications are subject to change without prior notice.
Product details: http://probox2.com/probox2-ex/
