What is 1.7 ROM? It is basically everything I did in 1.6 but applied to the new Yuandao ROM 0908 with Kernel 70.
Special note for this version! I found a small bug in the init.d support that could cause scripts to run over and over again. This has been fixed! Special thanks to FreakTab user SOWA for pointing this out!
The flash tool is setup to pre-select kernel #70 but like my 1.6 ROM, I have supplied all the other kernels for you to try if you like. I have also supplied a choice of 2GB or 4GB user APP space. 2GB is selected by default in the tool.
PLEASE read the readme.txt in the ROM kit for instructions how how to use the tool and chenge the options!
If you want to read the full description of what is 1.7, then look in the readme.txt file in the kit or read this post explaining it like my 1.5:
http://www.freaktab.com/showthread.p...d-latest-fixes!
_________________________________
Please do not upload to file sharing sites!
This is my personal request.
I hope you can honor it.
OK here is the download for my 1.7 ROM.
ROM -> Yuandao N101 - Finless ROM V1.7 CWM - init.d +Fixes (190 megs)
Enjoy,
