petrus app icons
Thanks man, that's great
If you could just make another version without the name AppInjector at the bottom, that would be perfect.
I'll try both, but as android will put the name under the icon, it might look weird on the applications menu.
But, that rocks, man. You'll earn a line in the credits of the about page
Oh yeah, and if I want to be picky, the background looks a bit low-res compared to the foreground. That would not be a real problem, as it will be small on the screen anyway, but on my PC screen, it looks a bit weird. But that's no big deal.
Another request : I'll soon release a new app called FileSystemManager, which aim is to mount/unmount, repair, and in fact manage file systems (SDcars, USB disk and other system devices). The app is ready, but I really couldn't make an icon. Even a shitty one. So I really need your help for that one. Maybe with a usb and/or a sdcard in it.
Here are some of the icons I use inside the app, if it can help :
Originally posted by tattman65 View Posthow about something like this[ATTACH=CONFIG]783[/ATTACH]let me know i can always change it up a bit i think this will work for your file system manager
I'm not trying to be kind, but you these icons are really kickin ass.
Thanks man
The background is really pretty nowThe whole icon looks really great
This one is really simple and clean. I really like itIf you can make the AppInjector one with the same background, that would be perfect
There are currently 1405 users online. 0 members and 1405 guests.
