- Step 1: You may not need a custom ROM but, you do need a custom RECOVERY for what we're about to do to root this device!
- This custom RECOVERY we're going to be using is called TWRP (thanks to abdul_pt for the port)
- I made this TWRP Recovery Install Package and you can get at this link: (TWRP Install Package)
- Once you download it Extract it into a new folder.
- Step 2: Installing TWRP
- Now that we have that folder, lets open it up.
- Make sure you install the drivers if you haven't already, then move on to the next step!
- Now navigate to Flasher_tool
- After that open "ROM_Flash_Tool_137.exe" without the quotes.
- Now plug your device in and hold the power and volume up buttons for several seconds until the flash tool says it's found!"
- Now click the "Flash ROM" Button!
- Step 3: Installing Root
- After it's done let the tablet boot completely up!
- Hold volume up and down keys (without device plugged in)
- Once it boots into TWRP go to Reboot then select System
- Once you do that it should detect that your device is not rooted and when it ask if you want to flash SuperSU, swipe to confirm you do!
- Reboot device and you should now be rooted!
- Step 3B: Alternate Rooting Instructions (Flashing zip manually)
- After your device finishes boot up open a web browser and navigate to (http://download.chainfire.eu/supersu) and using a file manager app like "ES File Explorer" copy the downloaded the zip to the root of the internal sdcard (No Real SD Card Required)!
- Once it boots up to TWRP select install and find the SuperSU update zip you copied earlier
- After selecting it swipe to confirm you want to flash it!
- Reboot Device after that and you should have root!
Follow all those steps and you should be rooted WITHOUT a custom ROM on the Hisense Sero 8!
