My MK808 is dead?
It's incredible!
Well...
I tried to replace the usb cable (power source) with my "old" Sony camera one and voilĂ ! It works!! Initially the image was wrong, with points, some kind of "static" and blinking some times and the sound was with some kind of hiss. I guessed that was an HDMI issue... And that was! My TV is 720p and not 1080p and the rom I'm using was 1080p by default (it is not a Finless ROM). I've changed the screen configuration and everything is running as it should!! See this video
Now my question is: it is safe to replace again my ROM by a Finless ROM, or i should keep everything as is?? The logic says that now I can do anything, but I must confess that the USB problem was so weird that I'm unsure about do it again :/Last edited by derekwildstar; 27 October 2014, 14:21.
Actually, the 720p Finless ROM has a small bug --- it's set to output 1080p by default. The only way to fix this is to connect it to a 1080p TV, then go into settings and switch it to 720p resolution, then power off. The 720p ROM wouldn't even work on my 1080i TV, it had to be connected to a 1080p screen in order to see anything. Finless ROM also has a bug where it cannot connect to wifi networks that use WEP encryption.
edit: btw, good job SolidMetal for thinking of that. I actually had no problem with the cable that was included with the mk808b, but a few months ago I did replace it with a different one anyway because the included cable felt a little cheap. I'm not sure if cable length makes a difference, but my new one is also shorter which might be a good thing
I definitely feel that a cheap cable makes a difference....i have a fan connected to mine that is powered from by usb hub that is connected to otg port. When i would do something cpu intensive with cheap cable installed i could hear the fan change speed. Since i changed my power cable the fan stays at the same speed no matter what i do. I actually made mine. I took a factory cable cut it apart and replaced with 1 pair from a cat 6 solid conductor bulk cable that i had. looks like hell but works well. The little short cable that comes with the stick works well it is just too short for my setup.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Yes!
The USB cable was the main problem! I would never think about it.
The situation related by prahjister is really weird and it's a proof that bad usb cables can be responsible by several problems apparently without solution.
My electronics knowledges are very limited. I never would imagine that an apparently normal conductor cable can be influenced by, e.g., intense CPU usage on the device
Well everything is OK now! Thank you all
There are currently 3023 users online. 2 members and 3021 guests.
