Internet via USB through PC?
    So how would I solve this issue?
    I have a Polaroid PMID701iX10. I have a laptop that connects to a network via cable. The network has no WiFi. Is there a way I can use a USB connection to connect the tablet to the laptop and share the network through the laptop?
    Is there some software I can install on the tablet or laptop or both to enable this?
    Radian
    Radian
    Google > Connectify
      Re: Internet via USB through PC?
      Radian
      If you're rooted, use 'reverse tether'
      sorry can't give you the link, I'm away atm. Try searching.
      Sent from my LG Optimus One using Tapatalk 2
