I have Amlogic 8726 bases MX2 (dual core) bought from ENY HD 18 v 2.22 PCB (Manufactured by Shiningstar) which I used for couple of days and then all of sudden when I turned on,, It shows no display on the screen however the blue light on the box turns on when the box is turned on and even when I press power off from the remote control it does turns off (the light turns off).
I tried to flash the orignal firmware again 2 times and also have tried Benni's idiot proof method of fixing the device.
I did noticed that when I would install any firmware, I could see the Android guy (Green guy) and it will show me recovery options as well however as soon as the installation finishes and the box restarts,,, again I see no display on the screen.
I hope some one can help me. I have read somewhere that this could be fixed by Uart method, but I am not sure how does that work...
This is the small video of the problem https://www.dropbox.com/s/z75tu6tezt..._0944.MOV?dl=0
Can some one kindly let me know or can anyone share a video tute?
