I will supply a full in depth review with shipping time andfuture comments after I have used it over time.
Just ordered ,will post extensive review
Originally posted by Musicboy View PostJust ordered from geek buying http://www.geekbuying.com/item/Trons...TS-326822.html
.geekbuying.com. it is a s89-h I 7days
hello customer
Good morning, how are you ? this is the service representative of geekbuying.
just now my workmate -Emma informed us , you have met problem of S89H , there is no signal of HDMI
do no not worry, we are here to help you, if we can not solve it , you can return us for new or for other new TVBOX , about the shipping fee we will pay for you and send you right returning address, before that , could you like to try as following ?
1.could you use a new charger and new usb cable to connect to power firstly, and the use a new hdmi cable to connect to other TV,
2. if it is the same, could you like to reset it to factory, and install the firmware here http://blog.geekbuying.com/index.php...ta-update-etc/
any other questions feel free to contact us any time, we will try our best to help you solve it
wish you and your family have a nice day
best regards
Anna
hi ana. I finished the try that you asked me. and after ????
all you have to explain to me I did. the only solution is to explain how to do the welding. I'm not young, I'm 67 and I do not speak french only french and hebrew. so it's more difficult for me this whole story
hahaha
Eventually I do not know. or rather yes. send the tv box and waits four months. and then I receive a recommance tv box HDMI does not work. ANA sends me an email I remade the testes. I refer the s89-h. and so on. I would have for my 69 years geekbuying EMA THANKS ERIC ANA
Originally Posted by totor54
YOU do not care for my face I see. but out eric said. all was OK. send to receive it in 4 months. Shame you had to lie to customers. it is simply theft. what you do. to say words you're champion. Sorry to make you feel inconvenience
I do not know who is not telling the truth is eric EMA or 2 are someone who does not tell the truth
Hi
We ship via the latest 108k4, and hdmi problem has-been solved, we double-check aussi Each device Before we ship.
Do not worry too much, at least you choose Geekbuying, We Will not disappear or what, we always stand behind our customer
Eric
The s89-h After Spet. Basically 15th is no problem with HDMI, the factory made further Top improvement improvements to the product. 3192718 is your order number, right? ACCORDING your box, you can send it back to get a new one
Well,My new unit came as advertised with latest firmware and hdmi seems to be solid.all apps work good getting to know the feel of the remote,I do have a air mouse/keyboard though that works fully with the tronsmart unit.only weak point I can see is the remote it comes with,but that is weak point for all the tv boxes.Geekbuying.com shipped it very fast I received it 6 days from the time of initial order.it was well packaged and secure.I have to admit I was a little skeptical from some of the negative posts that some were posting.that probably should have been resolved with personal messaging.So far I am very satisfied with my purchase.I Hace A satechi unit that the tronsmart replaced it was the A9 rockchip 3188 which was adequate ,but was very sluggish when I get a little more comfortable with doing a firmware upgrade I will try it on the sarechi unit.I will post more on the tronsmart atr a later time as I use it more and more.
Originally posted by Musicboy View PostWell,My new unit came as advertised with latest firmware and hdmi seems to be solid...
Had to re-solder it, but I will replace the HDMI port though, because of the poor contacts quality.
Otherwise a good working box, but cheapest components and a poor, overall build quality.
Lesson learnt, never again!
I guess, the few bucks more for a Minix are well spent.
Originally posted by vel2000 View PostLike mine, HDMI worked very well the first few weeks...
That is Exactly the way I feel on Every Point.HDMI is still working after 10 days,Lesson Learned,Stay Away From Tronsmart,Although I have gotten it to work decently,I will try the minix X8 next or the rockchip 3288.It is still early for these new chips lot more to be learned and prices will drop after the holidays.
Originally posted by Musicboy View Post....I will try the minix X8 next or the rockchip 3288.It is still early for these new chips lot more to be learned and prices will drop after the holidays.
The Tronsmart will be retired now and running as a "Home server" and Internet radio player, since I can't get a new HDMI port locally and I don't want to order a lot of 25 ports from China.
Also Bluetooth doesn't function with the 109 Firmware and one USB port works unreliable.
Time for a new toy.
There are currently 2046 users online. 3 members and 2043 guests.
