For whatever reason, I have decided to put a RikoMagic MK902ii in my car. To do this, I need to get a power inverter or other DC power source. I cannot find, anywhere, a definitive statement on the size of the DC plug required for this box. Does anyone know? Those barrel plugs come in a zillion sizes, so I'm not sure what size to get. I'm guessing the outside diameter is 5mm or 5.5mm and the inside is 2.1mm or 2.5mm? But it's impossible to tell from the pictures online, and the specs never say. Does anyone know the size of the barrel plug for the MK902ii?
Dumb easy question about MK902ii power plug
I know that there's no such thing as a stupid question, but I have one.
For whatever reason, I have decided to put a RikoMagic MK902ii in my car. To do this, I need to get a power inverter or other DC power source. I cannot find, anywhere, a definitive statement on the size of the DC plug required for this box. Does anyone know? Those barrel plugs come in a zillion sizes, so I'm not sure what size to get. I'm guessing the outside diameter is 5mm or 5.5mm and the inside is 2.1mm or 2.5mm? But it's impossible to tell from the pictures online, and the specs never say. Does anyone know the size of the barrel plug for the MK902ii?Tags: None
normally 5V DC use 5,5 x 2,1 mm ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by DarkCyrix View PostHi,
I think you can also power it using the USB host port if you want to.
Originally posted by no_spam_for_me View Postnormally 5V DC use 5,5 x 2,1 mm ...
There are currently 2077 users online. 8 members and 2069 guests.
