I already made a mistake buying an RikoMagic so I'd like to avoid the same. Seems like it is going to be between Tronsmart CX-919 vs MK908II.
Which is better? I can't tell the difference on **** or Amazom.
What is a good source? Is the fact that it will be branded a guarantee that it is genuine?
Thank you for patience....
Newbie learning after doing searches over and over....
