now the battery is emtpy and i don't know if it's wrong with the cube or the charger, anyone else with same problems?
Charger problem Cube U30GT
I recieved my cube u30gt yesterday and everything was perfect until the battery went low and i connected the charger but nothing happend no contact with the charger at all..
now the battery is emtpy and i don't know if it's wrong with the cube or the charger, anyone else with same problems?Last edited by Emil86; 25 September 2012, 09:18.Tags: None
Re: Charger problem Cube U30GT
The supplied charger is very low quality, source a replacement.900Supersport
freaktab developer
Emil that seems to still be the charger. For a U30GT W or H you need a 12 v 2000 mah supply. Most car chargers will not work.900Supersport
freaktab developer
Originally posted by Ben36 View PostSomeone should really find a good quality decent price aftermarket charger and post it as a sticky for all
Sent from my LT26i using Tapatalk 2
Here is one they sell for the cube u30 gt
Great service
http://www.****.co.uk/itm/12V-2A-Cub...-/120926525213
Sent from my SK17i using Tapatalk 2Please consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Emil86 View PostI went and bought a charger now and it seemed it worked it started charging and i went to bed 7hours later the cube is stone dead.. Nothing happens tried everything.. Can i do something or is it scrap? Tried ur bricking advises and nothing happens i think its broken ..
If you brought the cube local then i'd return it. If you brought from china i'd consider upening it up for inspection.900Supersport
freaktab developer
Look at one of the unbricking threads. You need to open it up, remove the 4 screws securing the metal frame and carefully remove it. It will peal away the thermal tape. Now conduct a good visual inspection. While you are here you mah as well try shooting the two reset pads and press power and see if you pc will recognize it. Good luck.900Supersport
freaktab developer
There are currently 907 users online. 0 members and 907 guests.
