MK808b v5 1.1 hopefully tonight
    after a little testing the new v5 rom netflix issue is gone..after applying vsync patch. Google movies and tv works....will try to finish rom tonight and post. I have some new scripts to add.. Ill have all the oc kernels as well.
    Is this ROM going to fully work (WiFi) on an old original mk808B (RK903) ?
    Thank you!
      Originally posted by mowgli View Post
      Thank you!
      Unfortunately no...but if you can deal without wifi or use an external it is worth it.
      im not gonna post yet...ill see if i can compile one.
      Have you tried the kitkat one?
        No, i haven't. May be I will. Thank you!
          update
          Running behind on this. Ran into a problem with mine turning off after sitting idle for extended periods. Thought it was a fluke but happened 2 nights in a row. Tweaking to fix this. And also since i am pushing the unit to its limits i want the sleep function to work.
            Is this kitkat? Also, is there a kitkat rom available for this stick. I have a few of them on hand. Would be nice to see a good kitkat rom for this device. Thanks in advance.
              uploading now. Will provide link in the morning.
