New Firmware for Probox2 EX
    Checkout the new firmware of PROBOX2 can be downloaded via :
    Download: http://probox2.com/category/probox2-ex-firmware/
    Upgrade method: http://probox2.com/firmware-upgrade-methods/
    Below are the summary for the major fix and new features:
    Major fix:
    • Fixed screen magnified problem when playing 1080P / 4K video clip in HDMI 720P output.
    • Fixed some portrait Apps can be usable in landscape mode.
    • Changed XBMC to 13.2 Gotham version to improve stability.
    • Make the physic power-key to be suspend/resume by press once, and long press for 5 seconds to shutdown.
    • Improve stability
    New features:
    • Allow to change wallpaper of PROBOX2 UI
    • Allow to add a app to multiple folders of PROBOX2 UI
    • Added Google TV Remote feature
    • Added SuperSU which allows for advanced management of Superuser access rights for all the apps on your device that need root.
    • Added shortcut key (by pressing “Menu” + “Home” button together) to release memory to increase system performance.
    • Added an Icon to show/hide Status Bar.
    • Support new feature DRM, Playready L1/L3, Widevine.
    Thanks,
    W2COMP
