New Firmware for Probox2 EX
    Checkout the new firmware of PROBOX2 can be downloaded via :
    Download: http://probox2.com/category/probox2-ex-firmware/
    Upgrade method: http://probox2.com/firmware-upgrade-methods/
    Below are the summary for the major fix and new features:
    Major fix:
    • Fixed screen magnified problem when playing 1080P / 4K video clip in HDMI 720P output.
    • Fixed some portrait Apps can be usable in landscape mode.
    • Changed XBMC to 13.2 Gotham version to improve stability.
    • Make the physic power-key to be suspend/resume by press once, and long press for 5 seconds to shutdown.
    • Improve stability
    New features:
    • Allow to change wallpaper of PROBOX2 UI
    • Allow to add a app to multiple folders of PROBOX2 UI
    • Added Google TV Remote feature
    • Added SuperSU which allows for advanced management of Superuser access rights for all the apps on your device that need root.
    • Added shortcut key (by pressing “Menu” + “Home” button together) to release memory to increase system performance.
    • Added an Icon to show/hide Status Bar.
    • Support new feature DRM, Playready L1/L3, Widevine.
    Thanks,
    W2COMP
    Cool flashed this the my EM8 square and it works just need to flash it with the remote updater.zip found in the EM8 section
      Can someone make a zip for SDCard update?
        Just extract the 3 files onto SD card and flash with toothpick
          Cool, thanks!
          I used the OTG cable to flash with the Aml flash tool instead.
          Sent from my iPad using Tapatalk
            Thank god I found this post.
            I got 2 of these units that seem to be bricked. The blue LED won't turn on at all, and nothing appears on the screen. I can't even get into recovery mode, so the and I'm completely lost when it comes to flashing the firmware via OTG. Any suggestions?
              Stane's MX Linux
              Can the PROBOX2 EX be flashed to Stane's MX Linux??
                Link not working
                  Here we go!
