Correct pins for shorting an MX2
As title states, I have looked for an image or even a post that show which pins I need to short to force boot from SDCard on an MX2. I have a few boxes that ar not responding to Benni's recovery image, I just get a blue light on the front and synchronous flashing lights on the ethernet port (when j45 plugged in).Tags: None
Maybe
and the following posts...
EDIT
Here we are http://forum.androidgadget.co.uk/showthread.php?tid=161
and maybe also have a look at
Has this thread helped you unbrick your device?Were you able to unbrick your device?Yes, from a "soft" brick2318.70%Yes, from a "hard" brick2721.95%Yes, from a "deep" brick3226.02%No, I was unable to unbrick my device4133.33%
(to identify the pin count)RK3288 Devices
- Overview BOX (LINK !)
thanks mate I will try these this evening, they are definitely hard bricked as the SDcard is definitely not being read.
edit 28/10
OK tried these, but one of those is for tablet and again the shorting for that board is not specified. This seems to be th problem I have is nobody can directly say, its these pins to get this board to force boot from USBLast edited by teleast; 28 October 2014, 23:47.
Originally posted by teleast View Postthanks mate I will try these this evening, they are definitely hard bricked as the SDcard is definitely not being read.
edit 28/10
Sent from my iPad using Tapatalk
Originally posted by teleast View PostI've run out of pins on the NAND to short
Checkout this method
The nand scrubber is here
There are currently 2941 users online. 0 members and 2941 guests.
