Help Mbox-Gbox
Help Mbox-Gbox
I need some help. I ordered 3 mx boxes from amazon, since i already have a mx2 from Marticom i thought it would just be as easy as toothpick method into the reboot and installing Matricoms software. From what i read i might have bricked 2 of them? I get the normal a9 symbol that appears then the android guy, which it dosen't move from there. I am still able to get on the reboot screen if needed. I was able to put linux on one of them with no problem but the power button does not work, Is there a fix for that? Anyways can someone help me with some advice on a build that allows the power to work on the controller or a way to get Matricoms software on the box? Every time i retry to put on any other software it aborts. Except linux..
There are currently 1988 users online. 0 members and 1988 guests.
