"Droidfish Test" on Cube Talk 9x or Teclast P98hd (MTK 8392)? need help...
    Could an owner of a Cube Talk 9x or a Teclast P98Hd run a "Droidfish Test" for us and tell us how many "nps" he/she find?
    I would be very pleased.
    Thank you very much !!
    (Don't let the apps running too long (2-3 minutes), because the device will heal !!
    Stop the apps or restart the device, if needed)
    Manual "how to" at the end of this post.
    Xiaomi MiPad ( 4 cores 32 bit) 1.357.000 !!! NEW HIGHSCORE !!!
    IPhone 6 ( Apple A8 64-bits dualcore 1,38 GHz) 1.270.000
    Ipad Air (2 64bit cores 1.4 Ghz) 1.218.000
    Iphone 5s (2 64bit cores 1.3 Ghz) 1.152.000
    iPad Mini 2 (2 64bit cores 1.3 GHz) 1.128.000
    TCL Idol X+ S960 ( 8 cores MT 6592 2.0 GHz): 1.112.000
    Zopo ZP998 (8 cores MT 6592 1.7 GHz ): 1.100.000
    Coolpad F1 ( 8 cores MT 6592 1.7 GHz): 1.087.000
    Star S4 Ulefone U9592 (8 cores MT 6592 1.6 Ghz): 1.080.000
    ASUS Transformer TF701t (4 cores ) 1.054.000
    Samsung Note10.1 2014 (4cores exynos) 1.014.000
    Samsung Galaxy Note2 (4 cores Exynos 4412 1.6 GHz) 714.000
    Samsung Galaxy Note 8.0 (4 cores Exynos 4412 1.6 GHz) 714.000
    ASUS Transformer TF300T (4 cores) 661.000
    Sony Xperia Z1 (4 cores) 602.000
    Asus Infinity tf700 (4 cores) 590.000
    Note 3 (4 cores Snapdragon 800 2.3 GHz) 581.000
    Galaxy S3 (4 cores Exynos 4412 1.4 Ghz) 574.000
    Cubot One (4 cores MTK 6589T@ 4x1.5Ghz) 568.000
    BQ Aquaris 5.7 5.7 (4 cores MTK 6589T 1.5Ghz) 566.000
    LG G2 556.000
    Pomp c6 (4 cores MT6589T) 553.000
    Pipo max M9 (4x cortex a9 1.6 ghz) 526.000
    Here's the directions :
    1) Install Droidfish:
    2) Clear all apps in background (hold home and swipe them away) and then run droidfish.
    3) Press the menu button, invoke "Settings", choose "Threads" and select "Automatic", and then press back button to get back to chess board.
    4) There is button with label "M" below chess board. Press it and choose "Analysis Mode". Analysis will start. Keep it running for about 1 minute.
    5) After 1 minute passed, read and record the "nps:" number at bottom of the screen. This is the measurement I'm interested in. This value is a number of positions searched per second (in thousands). The higher the better.
    6) To force program to stop thinking, press "M" button again, choose "Two players" so that analysis will stop. Post the results here with rom information. Stock rom is preferable but other roms are welcomed.
    Thank you!
    Tested on my cube talk 9x, stock rom of july 2014 (rooted):
    1.077.000 nps (I use a dynamic background that could affect the result)
