NEOCM10 "LEON" Jelly Bean Testing
Neo,
Any luck on the 10bG3 kernel fix for battery and GP?Randy
Neocm10 v1.25
Originally posted by neomode View PostPlease install Neocm10 v1.25.
This will fix the error.
Kind regards
Gesendet von meinem HTC HD2 mit Tapatalk 2
I installed the 1.25 on my 9G2 and still no rotation, also the sensor works but no so smooth, trying with temple run and I cannot get it running in the center, just all left or all right; also I changed the screen DPI and the screen icons for the nova launcher remains too small and couldn't change them, so I installed Apex launcher and is working OK.
I like really much your ROM, is running smooth and I have more free RAM memory than others ICS roms for 9G2.
Can you fix the rotation issue and probably to include the stock launcher along with nova or apex?
Rotation Fix
Yes i will work on the Rotation fix.
When finish i will PM you.
Kind Regards
Rainer
AW: NEOCM10 "LEON" Jelly Bean Testing
Hello,
This Problem we got before i do the Update. On the Child pad and on the 7g3 this is fixed. So when i am later at Home i will see how to fix the Error. Can you send me which Tablet you use 9xGx ? Thanks.
HardWare Info
Originally posted by tanfed80 View PostMy tablet is an A9G2.
Thx for the support.
And Send my Please the Hardware Overview to [email protected].
Thx
Rainer Trunk
There are currently 1867 users online. 0 members and 1867 guests.
