Just google tvmc install the apk .thats all you need to do .btw its i think from the xbmchub boysi have a tronsmart s89-h
for those who want a real working xbmc there is tvmc
First of all iam not the maker ore related to thr makers .i found on the net tvmc .its a allready customized xbmc13.2 version .with all the big programmes on it like icetv navi x .all you have to do is install the apk file and the rest is done .it is tested on a m8 .if been using it beside my 13.2 and untill now it works like a charm .iam using it a week now .
Just google tvmc install the apk .thats all you need to do .btw its i think from the xbmchub boysi have a tronsmart s89-h -
Yes It is I just installed on my new s89h,It is the same thing I must admit it is a lot easier to install but in general mos of the addons still are a joke with no links and subscription required which is not the addon.ag teams fault but the un controlled mass of addons not kept up to date.xbmc could be great but it should have tighter control of the addon community.I am a Simple consumer and do not know the first thing about this stuff ,but this is just my observation.
Originally posted by Musicboy View PostYes It is I just installed on my new s89h,It is the same thing I must admit it is a lot easier to install but in general mos of the addons still are a joke with no links and subscription required which is not the addon.ag teams fault but the un controlled mass of addons not kept up to date.xbmc could be great but it should have tighter control of the addon community.I am a Simple consumer and do not know the first thing about this stuff ,but this is just my observation.
iam using it for a week now for movies i dont use it for anything else and 4 me it works fine .untill now i havent got any problems with it .Only thing i mis is mashup but i think what one could say that is garbage the otherone likes it .they can never make a programm that satisfies everybody .
mashup is soo simple to install. The right sequence: http://install.mashupxbmc.com
Put that under system programs add line ...... afterwards system adon new addon trough zip file, select mashup, install reproB (under map repositories), wait a few sec's,
then add-on, download select mashup, video files, mashup and there you go.... piece of cake
There are currently 2198 users online. 1 members and 2197 guests.
