support USB Ethernet for MK808Bplus
Official Stock Firmware - Beelink S805 SoC(MXQ/MK808 Plus/MK809 Plus) -User feedback
I was donated a MK808B Plus....I took the stock firmware and cleaned it up...updated all the apps and a few other things....Anything you guys want me to place in it before i upload....any tweaks etc...I can only do so much but will try my best to accommodate.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Hey guys
I bought this box: http://www.gearbest.com/tv-box/pp_94466.html
Firmware level on it is 105k4 and seems a little dodgy. Was wondering will these versions of firmware work? which is the latest version available?
Originally posted by prahjister View PostI was donated a MK808B Plus....I took the stock firmware and cleaned it up...updated all the apps and a few other things....Anything you guys want me to place in it before i upload....any tweaks etc...I can only do so much but will try my best to accommodate.
thank you for your help
please put 2 or 3 launcher. not the kind of neo minix 8. not too gray sad. PROBOX2 by changing the icons thank youLast edited by totor54; 18 December 2014, 18:56.
Tried myself and everything is working as expected! Wifi and Ethernet speeds are good enough (for a device without external antenna). Bluetooth is working. UI speed is good. Used the sdcard .zip version in a usb drive WITHOUT .aml setting file (see Finless recommendations - used also in the usb drive his recovery and made a system reset in recovery before flashing ). First boot takes a long time.
Great improvement with respect to the 105k4 I had on board.
Regards
Inviato dal mio Nexus 5 utilizzando Tapatalk
Edit: must say to be true I downloaded version from Chinagadgetsreview on which the Fw was published on the 7th of January. But I believe they are the same as those mentioned in the previous posts!
Edit 2: tested the remote that came with the device and I must say with this latest FW it is close to perfect for the price tag!Last edited by vn800art; 15 January 2015, 13:22.
Never rest! Last bad news:
Mine MXQ S85 looks now died itself! Tested PS looks working and I also bought another one (working, from a physical store chain in Italy), no joy! No light, nothing at all. Bought the device from Gearbest.com , took more than a month to arrive, 10 days ago!
Edit: left the box connected with the original AC PS and it booted itself after maybe half an hour. Everything solved. Dunno what happened though!Last edited by vn800art; 17 January 2015, 21:42.
Originally posted by vn800art View Post. Used the sdcard .zip version in a usb drive WITHOUT .aml setting file (see Finless recommendations - used also in the usb drive his recovery and made a system reset in recovery before flashing ). !
can you provide a link to Finless recommendations please.
Thanks.
I bought an MXQ S85 from Gearbest as-well and it died in two weeks of light use. Same way your decribed no light, nothing on screen at all just stopped working. Sucks
There are currently 3516 users online. 0 members and 3516 guests.
