smb share
smb share
i have android tv mediaplayer with xbmc 13 i think can some one tel me how to see the usb hdd on my windows 7 pc there is no setting in xbmc only webserver buy you can do anything with it i want to add movies from my windows pc to my android box with 2 tb usb hdd its easy on my boxee box but not on android box with xbmc makes no sensen thanksTags: None
First install sambadroid apk from google play (device has to be rooted). Start apk and setup shared folder (add shares or manage shares), click on options, and click bootstart option. Click on start and that's it. On tv screen you have info about local address. Now click start on windows, then run. Type exactly same local ip, including backslash and hit enter. Your shared folder should be opened. You can add shortcut to your desktop, like i did, but first must setup static ip for android mini pc. Then after reboot address is the same, and sambadroid will autostart. You just need to click on the shortcut created on desktop. I also have 2 TB drive, works great.
Originally posted by gsavicic View PostFirst install sambadroid apk from google play (device has to be rooted). Start apk and setup shared folder (add shares or manage shares), click on options, and click bootstart option. Click on start and that's it. On tv screen you have info about local address. Now click start on windows, then run. Type exactly same local ip, including backslash and hit enter. Your shared folder should be opened. You can add shortcut to your desktop, like i did, but first must setup static ip for android mini pc. Then after reboot address is the same, and sambadroid will autostart. You just need to click on the shortcut created on desktop. I also have 2 TB drive, works great.
thanks for the help i wil try
There are currently 3028 users online. 1 members and 3027 guests.
