Un-Brick...Help me someone
Originally posted by RISCy Dude View PostHello, Have you checked the power supply(AC Adapter) to make sure it is putting out voltage? Check it with a multimeter if you can.
Thanks for the idea, but that's not the problem.
The adapter works fine, I've tried.
The way in which memory can be rewritten? Anyone know this?
I would really appreciate if someone would describe the process of ...
Maybe someone has tried ....
Thanks,
George
Originally posted by Droid-TV.fr View PostHello,
Does the M8 light turn blue? Is there a logo that appears on the screen?
Unfortunately not turn on the blue light does not come on the boot logo.
Nothing ...
In this case, you can still do something?
Perhaps two points are touching the motherboard to start a process?
If you have tips, please share it
Thank you,
George
Nothing ...
Thank you,
George
Only way to fix is to replace the PMU (Ricoh chip) you will have blown it if you have stuck finless 1.7 or 1.8 on it
Thanks,
George
I had the exact same problem. No light nothing. With help of the Probox updating tool i was able to bring it back to live.
There are currently 3537 users online. 0 members and 3537 guests.
