NEW - N101-1 Finless ROM 1.8 Jellybean - CWM, Init.d
    OK folks my 1.8 Jellybean ROM is ready!
    What is 1.8 ROM? It is basically everything I do in all my ROMs but this one is Jellbean built from the Official BETA Yaundao N101-1 Jellybean ROM with Kernel 21. Remember, at this point the Official Yuandao ROM is BETA so expect some bugs possibly. Although I am enjoying it myself and do not have a audio buzz problem some are complaining of
    I think this ROM is very smooth and performance is good at least based onmy testing so far.
    PLEASE read the readme.txt in the ROM kit for instructions how how to use the tool and change the system size options!
    Features in 1.8 JellyBean ROM:
    This is built from the Official BETA Yuandao JellyBean ROM.
    1) FULL init.d support! Now Scripts put in /etc/init.d will now run on boot.
    This means you can now play with the V6 Super Charger stuff, etc
    2) Of course full init.d Means full BusyBox install with all needed SYMlinks!
    3) This has my NEW ClockWork recovery "touch" Mod installed. The buttons will also work as well as touch screen.
    4) I have adjusted the parameter file for more app space! You now have a choice! 2GB or 4GB.
    Read instructions below for how to shoose which in the flash tool.
    By default I set up the tool for 2GB app space.
    5) Since /system is now RW, I have increased it's free space to allow rooted and system apps.
    6) Installed the latest working SU and SuperUser.apk
    7) Updated busybox to 1.19.x (1.20.x has bugs in my opinion)
    8) Debloated the ROM of the junk APPs. I also removed the Chinese and Japanese keyboards.
    However in the ROM kit is APP Injector. Use that to put back what you want.
    See instructions below.
    9) All older APPs and Google Framework have been updated to thelatest as of this date!
    So no updates needed from Google Play
    _________________________________
    Please do not upload to file sharing sites!
    This is my personal request.
    I hope you can honor it.
    OK here is the download for my 1.8 Jellybean ROM.
    ROM -> Yuandao N101 - Jellybean Finless ROM V1.8 CWM - init.d (256 megs)
    Enjoy,
    Great Work Bob
    Great work mate, I knew you would sort it out and provide Jellybean for our version of the N101.I will download it and install when I get back home to the UK. A Pitty Auzziepad were not more helpful, we certinly beat them to the finish line : )
    Regards
    Resl
      Looking forward to flashing tonight, maybe!!!
      Randy
      Randy
        Browser crashes on download (cleared data using TB -- still the same)
        Google Play disappeares on download (same with data).
        Lost all my data (probably because of parameter file).
        Yes, the new CWM is great (on second boot I had no touch working in there for some reason, but since then it's fine)
          Were you using 2gb or 4gb?
          Randy
            Were 2 gb before and 2 gb after. I probably had to unckeck it to save the "sdcard" contents.
              those that have installed it. can you still play the games from gameloft?
                Re: NEW - N101-1 Finless ROM 1.8 Jellybean - CWM, Init.d
                The flash went well.
                GP loaded all the usual stuff as expected.
                I have no mounted internal storage.
                External SD mounted OK, so TB worked.
                I haven't had time to test flash, or media. I'll test more Sunday.
                Randy
                Sent from my N101-FreakTab using Tapatalk 2
                Randy
                  After powering down to remove external SD, I rebooted. I got error stating storage was damaged. When I touched the error notification it asked me to format. I formatted (what the hell, right?), and after formatting I now have internal storage mounted.
                  I thought I would share that, in case anyone else had the same problem.
                  Randy
                  Randy
                    Install went fine. N101T model 1:2nd batch
                    Here's my results from a couple of hours of setting up and testing
                    Pros
                    • Cwm touch is awesome
                    • root does work (just in case some of you have been following whats happening with other JB roms)
                    • usb mouse works
                    • usb sticks works
                    • it's really smooth considering its a beta
                    • Bluetooth address is locked now so PS3 controller use is an option now, tested with 2 reboots and a power down then a 10 minute wait address stayed the same thru it all
                    • more options to tinker with in developing section
                    • snapshot feature now has a button option in the statusbar and has settings too.
                    • Flash does work tried a game with it
                    • Youtube audio sync rate is good on HD videos
                    Cons
                    • High frequency noise emitted from the speakers when circuit is powered.
                    -turn up brightness to 100% to eliminate or
                    -in sounds setting disable touch sounds and screen lock sounds but it comes
                    back when you play media
                    • When I powered it off it rebooted two times
                    • Massively lacking permission files (no usb.accessories and such can't use my xbox360 controller now but I'll look further into that when I have time)
                    Unsure
                    • Wifi signal could be better: 2 out of 5 tests showed a huge improvement but its random at best
                    Overall I'd say it is worth flashing.
                    Yeah my internal storage was corrupted too. rebooted it just incase that might have solved it but nope. So just plan on doing a factory data reset to reformat the internal sdcard if you have problems.
                    Lol this is one of the first things I checked out. So here's the list of games I own/tested and their results.
                    GameLoft games
                    • Nova 3 - works fine restored from TB and copying internal data back from computer.
                    • Modern Combat 3- works fine restored from TB and copying internal data back from computer
                    • GT Free+ HD- loads fine controls are still reversed from TB restore and internal data copied
                    • Gangster Rio- silent killed after opening language warning same as with ICS
                    • Asphalt 7- endless loop of Gameloft boot screen then license check(apparently others with JB have this problem too)
                    Others
                    • Mass effect Infiltrator- works fine but you have to reinstall it from the play market don't restore it with TB (if you do delete this file /data/data/com.ea.games.meinfiltrator_na/shared_prefs/com.android.vending.licensing.eapref.xml then just relaunch and download the data package again)
                    Thats all the high end games I own that I can Test.
                    Hope it helps
                    NextBook 7 Premium -S/N 0911 Running one of Many Finless Bob's Roms found here!
                    Yuandao/Window N101T (Model 1:2nd Batch) Running Finless Bob's 1.6 Rom kernel# 26
                    Found Here
                    ZTE Score (X500) running a rooted stock rom.
                      Pros
                      • usb mouse works
                      • usb sticks works
                      Cons
                      Unsure
                      GameLoft games
                      Others
                      Hope it helps
                      Thanks man great write up :thumbup:
                      Sent from my SK17i using Tapatalk 2
                      </form>
                        Уважаемый БОБ, ну как с вашего ресурса можно скачать? скорость 50 КБ/с - Ждать нужно около 2 часов, может вы тогда сами зальете на Другой ресурс или на http://www.yandex.ru/ или на http://www.mediafire.com/ ? Когда пару месяцев назад скорость с вашего ресурса была 5-7 МБ/с все было еще допустимо, но с такой скоростью выполнять вашу просьбу крайне тяжело. Я надеюсь на ваше понимание, и на то, что вы примите меры в данном вопросе..
                        С Уважением,
                        Сергей.
                          , ? 50 / - 2 , http://www.yandex.ru/ http://www.mediafire.com/ ? 5-7 / , . , , ..
                          Nice to see the Russian people taking the piss :thumbdown:
                          </form>
                            Это нормально?. Это просто ужасно!!!. Возмутимо!..
                            Вы хотите чтобы вашу прошивку не выкладывали, при этом ее скачать невозможно!!
                            Если вы что-то хотите, то сделайте для начала достойный сервер с которого можно было бы без проблем качать, а уже затем что-то просите...
                            Весь день сегодня пытаюсь с вас скачать прошивку - так еще ее и не до качал..
                            Я просто вынужден в итоге отказаться от нее в пользу vondroid.com c которых прошивка качается в 10-20 раз быстрей, чем с вас..
                            Очень плохо..
                            С Уважением,
                            Сергей..
                              I had to start sharing it from my pc. Privately for now. But this is retarded.
                              Bob, permit our community to mirror your n101' firmwares on our handy russian narod.ru, please.
                              I like JB's multi-users feature.
