I have reset and was going to just install the Finless 1.8 as I know it works fine on the box as I previously tested that. My issue is when I boot into recovery menu my remote wont let me select anything??? how do I fix this?
recovery issues
recovery issues
Hi everyone, I hope you can help me. I tried installing the JustMe rom and all went well until reboot. It loads up to boot logo then screen goes black.
I have reset and was going to just install the Finless 1.8 as I know it works fine on the box as I previously tested that. My issue is when I boot into recovery menu my remote wont let me select anything??? how do I fix this?Tags: None
Originally posted by Garymcc1 View PostHi everyone, I hope you can help me. I tried installing the JustMe rom and all went well until reboot. It loads up to boot logo then screen goes black.
I have reset and was going to just install the Finless 1.8 as I know it works fine on the box as I previously tested that. My issue is when I boot into recovery menu my remote wont let me select anything??? how do I fix this?Please consider making a Donation to freakTab
Well, I think that's enough
I suggest you to put, at the root of your SD card:- finless files (em8_finless18.zip + factory_update_param.aml)
- this recovery.img: https://mega.co.nz/#!ghdUXDZA!sGhhlk...dWazrhCSuDBwM0
Then try to boot to recovery, firmware will automaticaly install
There are currently 1665 users online. 1 members and 1664 guests.
