jelly bean succesfully ported !!!!!
    Re: jelly bean succesfully ported !!!!!
    you must rename the original file first and than copy the modded one
    Verstuurd van mijn GT-S5660 met Tapatalk
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
      Let me clarify here. I got all sorts of errors when I renamed the framework-res. Then the new one wouldn't copy over completely. I finally got it copied and rebooted and now it is stuck on the boot animation.
      Going to reflash and start over.
      Randy
      Randy
        Next time I will check the permissions
        Randy
        Randy
          ok step by step
          first with rootexplorer take copy modded file.
          than go to the original file and rename it first.yoy got errors thats normal.then copy immediately the modded file and set permission and reboot
          </form>
            OK I got it working.
            Something in systemui is making task bar disappear.
            Edit: Setting permissions fixed that.
            Randy
            Randy
              Cool. Snakegenmod on N101!!!!!
              Randy
              Randy
                ok can you post screenshots please then i make a whole rom
                </form>
                  Randy
                  can you give me the wright permissions for the files ?
                  is it rw-r-r for all the 3 files.
                  </form>
                    I just gave all permissions to both.
                    Right now, I can't get settings to run. It says it isn't installed. When I try to load the settings.apk it blocks the installation because it isn't set to side load an app
                    Since I can't get into security settings to change that...what do I do? Is there a back door to those settings somewhere...or was it set that way in your file?
                    Randy
                    Randy
                      Randy
                      now i just changed the icons .
                      the permissins are not wright i think.
                      can you go to the file with rootexplorer?
                      and change the pemissions
                      </form>
                        if its not work.
                        download your file that you uploaded again and copy the original back
                        </form>
                          I did that. Trying to run settings still says "app not installed". Trying to run it manually gives me the security error.
                          I'm sure I set this to allow unknown sources before I started, because I always check this after a reflash.
                          Randy
                          Randy
                            I finally got the old settings to load. I tried redoing the copy and setting permissions. Still no luck. Now I'm rebooting to see if that helps.
                            Randy
                            Randy
                              The reboot after setting permissions did the trick!!!!! Everything working now.
                              Randy
                              Randy
                                Randy
                                sow the 3 modded files works now?
                                if yes give me the correct permissions of the 3 files .
                                and i make a snakegenmod from this jelly bean
                                </form>
