details and download link here: http://www.stane1983.com/amlinux/
This is or is not test release. I do have only MXIII 1Gb device with Realtek wifi. However, both wifi modules should be supported. I need feedback from users with ap6181 if wifi works.
Install is with sdcard, however, you might not see any progress or you will see scrambled screen during install process. For some reason Android recovery system is not shown on screen. Once installed, device will reboot into AMLinux.
NOTE: This is firmware, it will erase your Android and all of your data
Update: 2014-10-26 version updated, lost settings issue fixed.
Cheers,
Stane1983
