i test diferent usb port...and diferent usb cable but the pc dont see......i am desesperate....some idea for revive my tablet???
i have a brick in yundao n101
Guest
hello i search a solution.....i was flashing jb...and i have a fail in the flash download......and my tablet dont turn on.....i probe power on + - but my pc dont see the tablet....
i test diferent usb port...and diferent usb cable but the pc dont see......i am desesperate....some idea for revive my tablet???Tags: None
Originally posted by ricky1992 View Postbeside usb port hdmi port
you will see "reset"
if your computer find your device, your tablet is not brick
There is a terminal that can be shorted inside on the motherboard if you open it up but you'd have to be quite desperate to do this.
There are currently 2942 users online. 0 members and 2942 guests.
