Preinstalled apk
XBMC 13.2 hardware decoding
Skype
Youtube
Netflix
Pandora
show box
super user
Add -ons
1 channel
mashup
sport devil
vevo
Iicefilm
F.T.V
Dragon sport
Genenis
GOTV
Step 1:
Downloads the file:
Step 2:
Unzip the file ,you will get 3 files and copy them to root folder of your SD Card. Insert the SD Card into your stb after you have removed power from it.(it must be sd card instead of USB driver .)
Step 3:
Insert a toothpick into the A/V port on the back of your Devices. Feel for the button hidden inside of the port. Press this button using the toothpick and plug the power back in, while holding this button. After 30 seconds release the button.
Step 4:
Then you should see Android sign with the update wheels spinning.
