M8N Square box 20141027 android firmware preinstalled xbmc 13.2 fully loaded powered by Sunnytvtech.com
    For some reason , we closed the download , if you want any new firmware ,please contact me [email protected]
    Step 1:
    Downloads the file:
    http://www.sunnytvtech.com/firmware/SU-M8N/*****
    Step 2:
    Unzip the file ,you will get 3 files and copy them to root folder of your SD Card. Insert the SD Card into your stb after you have removed power from it.(it must be sd card instead of USB driver .)
    Step 3:
    Insert a toothpick into the A/V port on the back of your Devices. Feel for the button hidden inside of the port. Press this button using the toothpick and plug the power back in, while holding this button. After 30 seconds release the button.
    Step 4:
    Then you should see Android sign with the update wheels spinning.
    Wholesale MX2 ,MXQ , M8 TV BOX
    100% origin version
    www.sunnytvtech.com
    China manufacturer
    aliepxress online shop
    http://www.aliexpress.com/store/234219
    Jason,
    Boy does this ROM have many problems!
    1) It is not rooted properly and you cannot update the SU binary as it fails. Thus running seeder APP or titanium, they cannot get root!
    2) XBMC will not work because it cant get root! Was this ROM even tested?
    3) Kernel is from Aug 27 so this build is a old SDK level.
    4) You have paid APPs or APPs that I am sure you did not get permission from the author to distribute in a ROM! This can get you in big trouble.
    Root Explorer which is a paid APP.
    Titanium backup which I know they do not like it being in a ROM!
    Others that probably not OK with the APP developer like the ROM tool box stuff.
    Finally and this is my opinion but putting in Show Box, Video Mix, etc which allows users to view illegal pirated movies I don't think is a good idea for a company to do! Also XBMC is fine but setting it up with mashup and other add-ons that allow users to watch illegal pirated content is also something as a company you should not do.
    So while I cannot tell you not to do that, it is really not a good idea for many reasons.
    I will continue testing this ROM but with it's many issues, users are not going to like it at all!
      HI BOB
      the xbmc can work only with new PCBA V1.0 above .
      1. yes , It is not rooted . we dont supply root firmware usually . there are many ways to rooted a devices
      2. XBMC can work , but only with new PCBA V1.0 above . Do you have the latest PCBA ?
      3.Kernel is from Aug 27 so this build is a old SDK level. Yes , Do you have any latest SDK ?
      4. Thanks for your information . i will asked our engineer to delete some paid apps next time . We dont want to get any troubles .
      Hope that you can continute to give us more feedback . thanks
      Jason
      100% origin version
      www.sunnytvtech.com
      China manufacturer
        OK ROM was not suppose to be rooted but you have superuser in there and it complains it is not updated!
        Also rooted apps you have in there fail. You should boot this ROM and see the problems.
        No I am sure I do not have the 1.0 PCBA. Mine is .92 or something.
        >3.[COLOR=#3E3E3E]Kernel is from Aug 27 so this build is a old SDK level. Yes , Do you have any latest SDK ?
        I do not personally but AML has a updated SDK from that date.
        Yes I will continue to give feedback but might be hard with old PCBA.
        Originally posted by jason_sunnytv View Post
        HI BOB
        Jason
          The new xbmc is really working well with the latest PCBA. And it encrypted , dont work with clone version.
          we preinstalled some apk or add-ons just want to make it easy for end users .
          100% origin version
          www.sunnytvtech.com
          China manufacturer
