First I checked to see if I had the original based on this thread:
I am under the impression that I have the original but feel free to tell me otherwise. Here is a picture.
So I went over to download ROM -> MK808 Original Finless 1.7c ROM (240 megs) from this thread: http://www.freaktab.com/showthread.p...ot-Finless-1-7 and managed to get the Flash Tool to detect my device after much searching. I followed the instructions and then got this the first time:
Apparently the issue with this is the USB so I went to use the back ports. This is what I got when I ran the Flash Tool again:
The computer still detects the device and the RKBatchTool shows the connected device, but hitting any of the buttons only gives me errors:
I decided to switch from PC to laptop, but I got the same result. The blue light no longer comes on so I am assuming it's bricked which lead me to this thread:
I tried to find the 8th/9th pin as best as I could using a needle and followed the instructions, but I haven't had any success. Unfortunately, I'm out of options and this is why I am here. I would really appreciate if you guys can help me with this.
