(Note: I just rebuilt my S82 from scratch and found out that section A and B are not supported in Launcher3 and MediaBox lauchers, only in Nova launcher. But I am certainly glad to have them!)
A. ANDROID HOME SCREEN SHORTCUT KEYS
Ctrl+Esc - Home screen context menu
Ctrl+N - Nova Launcher settings
Ctrl+M - Manage Apps in Settings
Ctrl+P - Settings, main system settings menu
Ctrl+S - Store, Google Play Store
Ctrl+W - Wallpaper manager
Alt+Spacebar - Opens Android search screen; sends to default browser
Alt+Tab (Alt+Shift+Tab) - App Switcher, hold down Alt key
Ctrl+Alt+Delete - Reboots instantly
B. GLOBAL APP SHORTCUTS ON WINDOWS KEYBOARD SUCH AS LOGITECH K400r
WindowsKEY+A - Calculator, open or switch to
WindowsKEY+B - Browser, open or switch to
WindowsKEY+C - Contacts, open or switch to
WindowsKEY+E - Email, open or switch to
WindowsKEY+L - Calendar, open or switch to
WindowsKEY+P - Music app, open or switch to
WindowsKEY+Spacebar = Opens Android search screen; sends to default browser
C. ANDROID DEFAULT BROWSER SHORTCUT KEYS
NAVIGATION
Esc - Go back, dismiss
Ctrl+Left Arrow - Back to previous page
Ctrl+Right Arrow - Forward to next page
Reload Page - Ctrl+R
SCROLLING
Spacebar, Page Down - Scroll down a frame
Shift+Spacebar, Page Up - Scroll up a frame
ARROW KEYS FOCUS ON THE PAGE ELEMENTS
Up Arrow - Move up one element
Down Arrow - Move down element
Left Arrow - Move left one element
Right Arrow - Move right one element
WHERE IS THE SUPPORT FOR THE HOME AND END KEYs? Mine don't work!
PageDown and PageUp keys will work if available
ADDRESS BAR
Ctrl+L - Shift focus to the address bar (doesn't always work)
Arrow keys move focus within navigation bar area; Spacebar/Enter selects
TABS
Ctrl+N - Open a new tab
Ctrl+T - Open a new tab
Ctrl+W - Close current tab,if last tab, return to Home screen
Ctrl+Tab - Switch to the next tab
Ctrl+Shift+Tab - Switch to the previous tab
Ctrl+1 through 8 - Switch to the specific tab
SEARCH/TEXT
Ctrl+F - Open the in-page search box
Shift+Backspace - Forward Delete (works like a normal "Delete" key)
BOOKMARKS & HISTORY
Ctrl+D - Bookmarks the current page
Ctrl+H - Opens the Bookmarks page
Ctrl+J - Opens download history as a popup
Ctrl+? - Browsing history (used to be H) WHAT HAPPENED TO THIS?
OTHER
Ctrl+Esc - Page context menu
Ctrl+G - Page info
Ctrl+I - Zoom in (depends upon context), three levels
Ctrl+O - Zoom out (depends upon context), three levels
Ctrl+P - Open Settings for browser
Ctrl+R - Reload page
Ctrl+S - Open Share popover with page destination options
including ES File Explorer (social networking sharing?)
