LOGITECH K400r INSTRUCTIONS/RECOMMENDATIONS FOR ANDROID TV
    LIST OF JUST THE FUNCTIONAL KEYS (from upper-left)
    Left Mouse
    Music Note - Opens Music app
    Home - Home screen
    PC/Lock - Opens Calendar app
    F3 unshifted - Opens Android search screen; sends to default browser
    F7 through F12 unshifted - Media/Sound controls
    Fn+Delete - Print Screen
    Fn+Ctrl = Menu - Context Menu
    TOUCHPAD
    One finger swipe - move mouse pointer any direction
    Two fingers scroll - move document any direction
    Zoom, pinch or spread - not currently supported in Android OS
    One finger single tap - left mouse button (cursor active)
    Two finger single tap - right mouse button (cursor active)
    One finger double tap - app context sensitive zoom function
    MOUSE BUTTONS
    Left mouse click - Tap with one finger or press left pad button; long press in
    an unoccupied area of Home screen - Launcher configuration
    Right mouse click - Tap with two fingers (when cursor is not sleeping) or press
    right pad button; long press brings up Bookmarks in Browser
    Left mouse, press and hold with simultaneous swipe, moves background in map apps.
    Fn + left pad button disables tap gestures
    Fn + right pad button disables edge gestures designed for Windows 8;
    RECOMMEND DISABLE EDGE GESTURES! (Seems to need this each time power switch is used)
    USING ANDROID OS - FUNCTION KEYS NOTES (from upper-left):
    Left Mouse - works
    Home - works!
    Power/PC - dead key
    Esc - Back, same as right click
    UNSHIFTED FUNCTION KEYS
    F1, F2 - dead keys
    F3 - Opens Android search screen; sends to default browser
    F4 through F6 - dead keys
    F7 through F12 - Media/Sound controls
    Insert - (what does anybody use the Insert key for?)
    Delete - works
    FUNCTION KEYS + Blue Fn key
    Fn+F1 through F12 - dead keys, unassigned
    Fn+Insert = Scr Lk - (what does anyone use the Scroll Lock key for?)
    Fn+UpArrow = PageUp - dead key in browser (NEEDS TO BE ENABLED!)
    Fn+DownArrow = PageDown - dead key in browser (NEEDS TO BE ENABLED!)
    Fn+LeftArrow = Home - dead key in browser (NEEDS TO BE ENABLED!)
    Fn+RightArrow = End - dead key in browser (NEEDS TO BE ENABLED!)
    Track pad mouse accelleration can be adjusted in Android Settings/Language & Input;
    Scroll to the bottom until you find Mouse speed.
    To fully reset K400r - Remove the batteries. Make sure the power switch is OFF. Press any three keys for at least thirty seconds. Low batteries will cause flakey operation. Put the batteries back in and turn the keyboard back on. This should fix 90% of issues--if not it's time to start removing software/drivers that may be causing conflicts.
    Beelink S82 M8B MediaBox ... Android Kitkat 4.4.2 ... Vigica MX3 Air Mouse (Aerb, Sannysis) ... Logitech K400r
    SIMPLE MEDIA CENTER USING GOOGLE DRIVE
    ANDROID EXTERNAL KEYBOARD SHORTCUT KEYS [DOCUMENTATION]
    NOVA LAUNCHER SET UP FOR INTERNET TV
    DOCUMENTATION?
    Best keyboard for the living room period.
      thank you to share.
      in spanish qwerty you can do zoom in and out pressing ctrl+¿ or ctrl+?
      and pressing windows+"+" can do double screen
