CS968 TV box and VPN apps
    hi,
    just trying find help with my TV box. I have this one with this ROM htc_t018_pubilic_MTK_20140225.img
    [IMG]http://i.****img.com/00/s/ODAwWDgwMA==/z/IgkAAOSwU9xURhrl/$_12.JPG[/IMG]
    I need VPN service as Tunnel Bear for watching Netflix and som UK programs, but unfortunatelly not working at all. I tried lots of VPN apps from playstore but no working any one. Why is this problem with this tv box? And how can i fix it?
    Very thanks for any help...
    Originally posted by jaaty View Post
    hi,
    VPN works just awesome with the box in the above photo ...! Go the player store, get the free$$$ Tun.ko Installer app, make sure you follow the directions, install everything correctly ... Open your desired VPN app and connect, that's it guy, you are now good to go, take care, enjoy ...!
      thanks... I got reply from Tunnel Bear and there is answer:
      Unfortunately TunnelBear is not currently with Android TV boxes due to the custom interface/ROM that these devices use. We apologize for the inconvenience.
      I'll download probably your? ROM (Android TV-220-Ultra-Test-9272014-1080p-AP6210_update.img - https://plus.google.com/communities/...artnerid=gplp0) and now TunnelBear works... Next time i'll try your advice about Tun.ko Installer app...
      lots of thanks
