rom for xt-q7-v11
    rom for xt-q7-v11
    I have a cs918 android tv box xt-q7-v11:
    My android system got stuck so I decided to try and flash my cs917 with a Rom. I downloaded a stock firmware http://www.mediafire.com/download/zq..._update(1) from the forum. at the time i didnt know its a firmware for a different version of q7.
    I used the rkbatch 1.7 tool and followed the instructions to flash the device. the box in the rkbatch tool went from pink to green as it should, I uploaded to firmware and pressed "restore". the rktool started to work but in the middle it stopped and wrote " Idb fail" and my device cant be turned on (the power botton is red).
    Now, when I plug my device and start RKbatch tool, the box is blue and I cant flash it with any firmware/rom.
    Please, Neeeeeed Help!!!!
    Thanks,
    Sami
    Originally posted by samia View Post
    [ATTACH=CONFIG]8601[/ATTACH]
    Thanks,
    Sami
    Try this firmware: Firmware download link
    Just click the 下载 BUTTON to finish the download. (Sorry,i haven’t got time to upload to other place, the download speed should be a little slow, but it can be downloaded)
    This is the official android 4.4 kitkat firmware, without rooted
    Firmware update instruction should be the same as this:
    Here is the instruction for how to update firmware on K-R42 quad core tv box: 1 Download the stock firmware from www.geekbuying.com/geekgiz; Download flash tool Here: http://www.mediafire.com/download.php?b9ckxat6t4cw5qc Password: GEEKBUYING.COM Drivers […]
      Worked!
      http://blog.geekbuying.com/index.php...d-core-tv-box/
      HERHAC,
      Thanks, worked like a charm!
      If you need any assistant in lawer stuff , contact me...
        Issue with storage on model-xt-q7-v11
        My cs918 model xt-q7-v11 has 2gb memory and 8GB nand flash. after installing the official 4.4 kitkat android, i am left with about 1.6GB "intrenal storage" and 4 GB of "nand flash".
        Now, when i install xbmc and watch some movies, the movies are streamed to my nandflash. after a while my availabe storage is out and i cant watch any movies/load xbmc and sometimes my android system does not load at all. at that point, I need to install a fresh official kitkat android to reset the system.
        Does anyone has a solution for my problem?
        Thanks,
        Samia
        HERHAC,
          link not working
          hi
          iam having same problem but the link to download rom provided above is not working
          kindly provide a valid one thanks
            Hi, i am also looking for XT-Q7-V11 RT3188 firmware without root. Can you please upload the rom again because the link is not working
              Hello, the firmware link for XT-Q7-V11 RT3188 does not work, could you reupload it? , thank you so much
                Hi ,
                even if it not works you must not ask in other Threads or make new ones , you can ask the
                User with PM if he still has the Firmware , and a small INFO RK3188 is about 10Years old ,
                buy new , no Support ,
                gefattern
                  [QUOTE=gefattern;n834038]
                  Hi ,
                  gefattern
                  [/QU
                    [QUOTE=KerHac;n356064]
                    ,,,,,,,,,,,,,,,Solved
