Trying to mount a router attached hard drive
    Ok need some help. I have a router which has a usb port on the back. I have plugged in an external hard drive and can see and move files to and from the hard drive to my Vega S89 using ES file explorer. I would love to be able to mount the folder on the harddrive such that I can download torrents directly to the harddrive connected to the back of the router. Can anyone help? Thanks :-)
    Says it's for Nexus 7, but this guide may point you in the right direction, if it works you create a mount point for the drive which acts just like a folder on device http://reviewlagoon.com/nexus-7-tuto...re-as-a-drive/
      Thanks.
      Appreciate the link Neoman. I was on the right track but for the life of me I could not get the modules to load. I tried everything. I just get a gray check instead of the green one. Any other suggestions?
        Looking around looks like 108k4 added support for CIFS, so it's possible the equivalent modules for the kernel on box are already loaded. Maybe try just skipping the loading part?
          Input / output error
          I get an input/output error.
            Maybe....
            Found this haven't had a chance to really try it though.
              http://www.freaktab.com/showthread.p...s-V1-2-0/page6
              i know that with my Aussie Thompson Modem , the usb drive had to be formatted to fat32..
              Sent from my Commodore 64 using Geos
              My devices:
              Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
              Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
              Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
              HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
