Pipo P8 RileyROM 1.4 [Android 4.4.4]
    Dear Randy,
    Does this 1.4.2 include the TWRP recovery? The recovery is powerful but the tablet cannot display the full screen and cannot work in landscape mode. No control menu or button available.
    Besides, can the flash be done on USB stick? without working with PC under "Rriley" rom?
    HY
      I test Rom 1.4.2 and
      GPS : OK (AndroiTS GPS tes, Navigon)
      Sim 3G call OK
      Sim Data. I have config APN. Sometime it work, and sometime it not work. I don't know why
        Donation
        I have make donation : confirmation paypal 6K3073605C057330B
        Thank you for your work
          Look in the RileyROM folder for the TWRP recovery file. You can flash it by itself.
          There are several technical reasons requiring a PC to flash this ROM. The only way to change the partition sizes is to flash the parameter file with the flash tool.
          Randy
            hi
            Some questions:
            Is battery drain on idle fixed?
            Is it true that internal file system is vfat with 4gb file limit?
            Online I saw a 32 gb rom version, is it true?
              Only testing will show us any difference with the battery drain. I will have to have actual users to report their results.
              If you format your SD card to NTFS you should get greater than 32gb. As far as the single file size limit, I'm not sure.
              Sent from my ifive_mini_3GS
              Randy
                R: Pipo P8 RileyROM 1.4 [Android 4.4.4]
                I am speaking about internal rom file system. Please can you check the internal partition trough mount command in terminal emulator? You will see file system type..
                  The system is ext4
                  Randy
                    The system is ext4
                    Data partition is ext4 as well?
                      i some problem
                      thx update.
                      i find some problem.
                      gps receive very slow from south korea.
                      good gps from 1.2 version. only 1.4 version problem
                      this problem same too oma rom
                        v1.5 is now available with possible fixes to overall battery drain...and power consumption in sleep mode.
                        Randy
                          Thank you Riley
                            The system is ext4
                            Hi rrileypm,
                            Please wich is internal sdcard (or emulated 0 ecc.) file system? I hope it is not vfat with wich we cannot write files > 4GB.
                            THANKS
                              Honestly, I don't know right off the top of my head. Sorry. I'm in the middle of some major ROM work at the moment and I can't check. I'll let you know if I find out.
                              Randy
                                Ok thank you. If you have time you can type 'mount' in terminal emulator and check all partitions. Maybe all pipo tablets have the same file system
