PMID710X: Flipped / mirrored touch and axis problem
    Hey, guys!! The problem is that my screen is mirrored, and the touch display sensor doesn't work properly (e.g. I touch the bottom of the display, and instead a function on the top of the screen is pressed). I have to use the tablet in front of a mirror, and pressing the screen in wrong places. I've gone into recovery, wiped it, and it stays the same. From what I've been reading so far, I think I will have to dump my ROM and save it, and then try to find another ROM for my tablet (there's no support for this particular model at polaroid's support site), that will have wifi, touch, and everything working again. But before doing anything stupid, I first wanted to ask the experts here. Please help me resolve this issue. Thanks in advance. My exact model is PMID710X, BN 08.01.002.035.01
    Extra information obtained via CPU-Z application:
    SOC:
    Rockchip Rk2928
    1.01 Ghz
    CPU Achitecture: ARM Cortex-A9
    Cores: 1
    Revision: r3p0
    Process: 40 nm
    Clock Speed: 216 MHz - 1.01 GHz
    CPU 0 : 216 MHz
    CPU Load: 6%
    GPU Vendor: ARM
    GPU Renderer: Mali-400 MP
    Scaling Governor: Interactive
    System:
    Model: PMID710X(rk2928sdk)
    Board: rk2928sdk
    Display 08.01.002.035.01
    Hardware: rk2928board
    Android version: 4.1.1
    OpenGL ES version: 2.0
    Kernel Architecture: armv7l
    Kernel version: 3.0.36+ (20130725.173526)
    Screen Resolution in pixels: 800x444
    Screen Resolution in dp: 1066 x 592
    Screen density: 120dpi
    Total Ram: 394MB
    Available RAM: 137MB (34%)
    Internal Storage: 0.98GB
    Available Storage: 0.81 GB (82%)
    Root Access: yes
    Sensors:
    MMA8452Q 3-axis Accelerometer
    X=-8.3 m/s 2
    Y= 0.5 m/s 2
    Z= 5.5 m/s 2
    AK8975 3-axis Magnetic field sensor
    AK8975 Orientation sensor
    ST 3-axis Gyroscope sensor
    AL3006Proximity sensor
    AL3006 light sensor
    Rotation Vector Sensor
    Gravity Sensor
    Linear Acceleration Sensor
    Orientation Sensor
    Corrected Gyroscope Sensor
