I have some problem playing some AVI file. The movie are playing but it look like to be play at an anormalous speed. less than normale, like less frame per second. and other video at 1080p (mkv 10Go) without any problem.
So I don't think the problem come from my LAN speed.
Can it be a codec problem (missing or wrong version) ?
Can it be a problem of the resolution of the video ? or a problem of audio/video syncro ?
Can I check something in a log file that can help ?
Thank you in advance for your help.
Regards
