Stuck on boot logo
i found some zips i cound flash that are supposed to switch it back to Davlik but they dont work.
Any ideas?Last edited by isham.padron; 04 November 2014, 23:07.
OK I fixed it. What I ended up doing is going into TWRP and using the file manager i copied the persist.sys.dalvik.vm.lib in data/property/ to the SD card. Pulled out the SD and edited the file in my tablet. The file was somehow missing libdvm.so. I added that and copied that back to the rom using TWRP. rebooted and now i'm back to normal.Last edited by isham.padron; 05 November 2014, 01:39.
Originally posted by isham.padron View PostOK I fixed it. What I ended up doing is going into TWRP and using the file manager i copied the persist.sys.dalvik.vm.lib in data/property/ to the SD card. Pulled out the SD and edited the file in my tablet. The file was somehow missing libdvm.so. I added that and copied that back to the rom using TWRP. rebooted and now i'm back to normal.in future simple made and keep on micro sd card. full backup of your rom.
There are currently 5778 users online. 1 members and 5777 guests.
