best box to buy mxiii or m8
    hi all great forum love the time and effort you guys put in this is my first post
    i am looking at getting an android box for xbmc and was looking at the s802 chip seems the best at the mo for xbmc
    i am looking at 2 boxes mxiii and the m8 both have 2gb ram and there is only £3 difference in price
    just wanted to know what your opinion or what you would recommend
    this is the site
    thanks a lot
    keep up the good work
    If you want to use it with Android, take the MXIII (2GB) because much more better support here at the forum and also better stock FW (rom).
    If you want to use it with OpenELEC (a small Linux only using XBMC) then there is at the moment a better support at the M8 BUT if I'm not wrong only with the right pcb (motherboard) and not at clone pcb???
    RK3288 Devices
    - Overview BOX (LINK !)
