Does the P4 and P9 use the same power adapter?
    Hello!
    The reason i'm asking is that i'm want to buy two P4's for my kids, my spouse already has a P9 and I do not what another power adapter. If they cannot share, then the kids will get the P9.
    Here's that I have today:
    P9 uses 5V 2.5A
    P1 uses 9V 2.5A (my tablet)
    M1 max uses 5V 2.5A (the old tabs)
    P4 charger
    Had P4 for about 2 weeks and was able to use my old charger for M8 Pro which was 5V 2.5 A now I'm using the same charger for the T9 . Hope it helps.
    Ps. The only difference is that for new P model range the charging pin is a bit shorter
    Proud owner of :
    Pipo M8Pro
    Pipo T9 that replaced P4
    Jelly Bean replaced Kitkat because of Flash support !!!
      Pipo P4 charger info
      I just got my P4 in from China 4 days ago. It is so good. I took a picture of the charger showing the manufacturer's info about it, hope it helps. I also put the connector in the pic so you can see what type it is.
        thank you!
        Looks like it's the same adapter.
          Re: Does the P4 and P9 use the same power adapter?
          I have both tablets...the chargers are the same.
          Sent from my P1 using Tapatalk
          Randy
