NEW - Leolas ROM V0.95 for Beelink R89/Tronsmart R28 and compatible RK3288 devices.
Originally posted by gaetanolip View PostYes, full HD movies > 4gb.but with vfat it is impossible
R: NEW - Leolas ROM V0.95 for Beelink R89/Tronsmart R28 and compatible RK3288 devices.
Originally posted by Finless View PostPutting movies on internal is a waste anyway.... A external SDcard formatted NTFS will solve your issue with 4GB files.
NO to userdata partition on KitKat! Vote now.
Good point gaetanolip. Writing data in small chunks is much more practical and safe onto internal memory rather than external SD card especially when RockChip tends to use caching technics (rknand_buffer).
Personally I am against internal VFAT partition on Android KitKat. Primarily because there is almost no use for it when Internal SD is emulated from main data partition which use EXT4 file system.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostGood point gaetanolip. Writing data in small chunks is much more practical and safe onto internal memory rather than external SD card especially when RockChip tends to use caching technics (rknand_buffer).
Almost certainly yes, but probably it will not mount on boot without custom script in init.d directory. If you don't know what it is or if kernel in this firmware use it then don't try this at home on you own hand.
Maybe Leolas will consider proposed changes to userdata partition: 1. romove it or 2. format it to EXT fs.
Eventualy you can make your own parameter file for this firmware and remove this partiton on your own. But you might loose internal SD "drive" if there isn't any emulation. I'm not shure about that because I haven't seen this firmware yet. Maybe tommorow.
Screen blanks out every 30 seconds or so
Hi Everyone,
So excited to see new developement of ROM's for the R89
I have had mine for a few weeks now and so far it's been great.
Today I downloaded and installed the new Leolas Rom and so far it is great.
The only think I am finding is that every 30-60sec the screen blacks out and then after a sec or two it comes back. Doesn't matter if I am using it or it's idle.
Is anyone else seeing this?
Re: NEW - Leolas ROM V0.95 for Beelink R89/Tronsmart R28 and compatible RK3288 devices.
Never tried to use internal sdcard in other partition type, but I will take a look on it.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I can't test 4k because I don't have a 4k screen.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostIt didn't happened to me, is this with this ROM or with all ROMs? What resolution you have?
The only other ROM I have tried is the 110K stock ROM and it was fine.
I am using 1080p 60hz.
Nothing installed fresh burn. I am using a Arctic mini wireless keyboard but that's it.
I am going to try the Finless ROM as well just downloading.
I tried the finless rom and it has the same issues.
I tried the FireFly image and it works fine. Linux work as well even wifi
Originally posted by scandog View PostI tried the finless rom and it has the same issues.
I tried the FireFly image and it works fine. Linux work as well even wifiREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Leo,
I upload the latest RK code(master branch) to YOU, include :
1.CEC support;
2.3D ISO support;
3.Update FFMPEG;
4.Support ext4 file system U-disk;
5.Strengthen Ap6335;
6.Improve camera/Skype.
7.Many other tweaks.
Do what you like.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 2422 users online. 1 members and 2421 guests.
