Adjust display output position
    Is there any possibility to calibrate the dsiplay output position in the two axis (up/down or left/right) ??
    In the settings there is only the zoom function in percentage, but this is not what I'm looking for.
    The position of screen is a little bit to high, this is the reason for my question.
    Settings Box:
    HDMI passthrough
    1080p 60 Hz (fix)
    LED: Native 1080p (without any adaptions)
    Ainol Aurora II (CyanogenMod 10.1)
    Ainol Flame NP 20130916 (CyanogenMod 11 (4.4.4))
    Lenovo Yoga 8
    Geniatech ATV1200 (UBoot 20130805; MyGica Build 20130927; XBMC Gotham 13.1 RC1)
    Tronsmart Vega Standard (Stock 108K4; xbmc-13.2-Gotham-4K-video-2160P)
    Ok, solved.
    Was more or less my mistake, because my little daughter have adjusted screen position from LCD. So solution was quite simple, but i have forgot that possibility was also embedded in marantz remote I use for AVR and LCD, but also to start and switch off the tronsmart box.
    However my daughter (7) normally have no problem to act with the box (start box, start NAS server, start XBMC, select Kids section and shut down again at end).
    Lenovo Yoga 8
