Draco AW80 - Hardware / Thermal / Case issue & feedback here
Originally posted by eltdesign View Postmine telos model really had strange power problems.. not everytime device getting to boot (trying several times to plug and unplug power cord to test) also need to wait some time and device can boot after...anyone experienced this before?
Originally posted by funio View Postyes, I have the same problem, it's really annoying, even more disturbing bcs there is no physical power button. I read somewhere that it could depend on running apps, but that's not correct. It doesn't help if you kill all apps before power off. The problem persist.
SD Reader
Originally posted by no_spam_for_me View Post:
Conclusion:
Maybe the build in reader is spec 3.0 and because the read (Sequential/Random 512) at the QUMOX is much faster, the first boot is also much faster at the QUMOX...
But of cause we need the running system and not the preparing system [IMG]file:///C:/DOKUME%7E1/FUN/LOKALE%7E1/Temp/msohtml1/01/clip_image002.gif[/IMG]
First I tried it with the QUMOX, because I know it has good Sequential reads...
I'm using deadhp1 Linux at SD (http://www.freaktab.com/showthread.p...l=1#post267520) THX
Write speed
dd if=/dev/zero of=speedtest bs=1M count=1000 oflag=direct conv=fdatasync
Code:1048576000 bytes (1.0 GB) copied, 123.299 s, [B]8.5 MB/s[/B]
Code:1048576000 bytes (1.0 GB) copied, 63.3088 s, [B]16.6 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 84.065 s, [B]12.5 MB/s[/B]
dd of=/dev/null if=speedtest bs=1M count=1000 iflag=direct
Code:1048576000 bytes (1.0 GB) copied, 52.82 s, [B]19.9 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 52.8185 s, [B]19.9 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 52.8191 s, [B]19.9 MB/s[/B]
Because I want to be clear at the different write speeds, I use my EVO and redo it
Write speed
Code:1048576000 bytes (1.0 GB) copied, 72.1097 s, [B]14.5 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 72.161 s, [B]14.5 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 71.9985 s, [B]14.6 MB/s[/B]
Code:1048576000 bytes (1.0 GB) copied, 52.2397 s, [B]20.1 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 52.2849 s, [B]20.1 MB/s[/B] 1048576000 bytes (1.0 GB) copied, 52.3683 s, [B]20.0 MB/s[/B]
Because I like iozone to test port/device performance and I will also do some other test, I downloaded it and compiled the program:
Filesystem benchmark freeware performance iozone disk IO solaris bsd freebsd netbsd bsdi hpux aix posix thread cluster file mmap async bsdi stream OSF Windows SCO read write NFS
=> Stable tarball
Code:tar -xf iozone3_430.tar cd iozone3_430/src/current make linux-arm
Code:./iozone -e -I -a -s 50M -r 4k -r 512k -r 16M -i 0 -i 1 -i 2 -f iozone.dat
Code:random random kB reclen write rewrite read reread read write 51200 4 3369 3534 8287 8375 8294 3640 51200 512 17146 18051 18635 18841 18835 18022 51200 16384 19755 19005 21094 21092 20657 18945
RK3288 Devices
- Overview BOX (LINK !)
USB Ports / SATA Port
You maybe would ask your self, why do I also test the SATA at the same post?
Because the SATA Port is connect to an internal USB 2.0 root-hub...
I use the QUMOX SD at a Transcend TS-RDF5K USB 3.0 reader because of the reader test above I already have an ext4 partition at it.
Code:/dev/sdb7 on /media/linaro/1ba5ba96-17c8-4a63-b88a-cbc7b1a7822e type ext4 (rw,nosuid,nodev,uhelper=udisks2) sudo ./iozone -e -I -a -s 50M -r 4k -r 512k -r 16M -i 0 -i 1 -i 2 -f /media/linaro/1ba5ba96-17c8-4a63-b88a-cbc7b1a7822e/iozone.dat
Code:random random kB reclen write rewrite read reread read write 51200 4 842 934 4472 4502 4033 864 51200 512 12101 17913 30408 30386 29963 19331 51200 16384 13039 18328 32408 32371 31827 10742
USB 3.0
Code:random random kB reclen write rewrite read reread read write 51200 4 985 1120 5697 5733 4789 848 51200 512 13459 21280 56912 57430 54374 23096 51200 16384 14025 14948 62239 62851 65016 14672
Now I use the external USB 3.0 HDD which I know it works at the USB 3.0 at Android...
(Hitachi 320GB 2.5 SATA-II (HTS545032B9A300) at case using AS media AS2105 chip-set)
Code:/dev/sdb1 on /media/linaro/USB-HDD type ext4 (rw,nosuid,nodev,uhelper=udisks2) sudo ./iozone -e -I -a -s 50M -r 4k -r 512k -r 16M -i 0 -i 1 -i 2 -f /media/linaro/USB-HDD/iozone.dat
Code:random random kB reclen write rewrite read reread read write 51200 4 4519 4900 5229 5428 474 1257 51200 512 25459 25745 25779 27072 17861 26962 51200 16384 29335 30513 30342 31633 31418 29582
Code:random random kB reclen write rewrite read reread read write 51200 4 10623 13264 14923 14863 572 1523 51200 512 62154 74330 81038 76349 32919 28307 51200 16384 78517 76412 72410 73333 76539 78213
Code:random random kB reclen write rewrite read reread read write 51200 4 5595 5699 6038 6057 549 1452 51200 512 27630 30324 30750 30615 19875 29482 51200 16384 31607 32756 31037 31936 32012 32186
RK3288 Devices
USB HUB's
A lot of root-hubs, that's nice
(VID=0C45 PID=8888 => USB HID Device => my iPazzPort KP-810-1 Air Mouse)
Code:Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub [B]Bus 001[/B] Device 012: ID 0c45:8888 Microdia [B]Bus 001[/B] Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB [B]Bus 001[/B] Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The Hitachi 320GB 2.5 SATA-II (HTS545032B9A300) at the SATA
Code:Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub [B]Bus 002 [/B]Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge [B]Bus 002[/B] Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 009: ID 0c45:8888 Microdia Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Because I use 2 RF receivers, an USB pen drive (USB 3.0) and a cable wheel mouse, I use a passive USB 2.0 HUB to plug it at the device where I'm actually working...
Same output at USB 2.0 port 1 and 2...
Code:Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub [B]Bus 001[/B] Device 014: ID 125f:312a A-DATA Technology Co., Ltd. Superior S102 [B]Bus 001[/B] Device 013: ID 0c45:8888 Microdia [B]Bus 001[/B] Device 012: ID 04fc:0015 Sunplus Technology Co., Ltd ViewMate Desktop Mouse CC2201 [B]Bus 001[/B] Device 011: ID 11c0:5500 [B]Bus 001[/B] Device 010: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB [B]Bus 001[/B] Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB [B]Bus 001[/B] Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Because I had trouble with two USB 3.0 HDD at Android I also test the USB 3.0 HUB, which I bought last week, at the USB 3.0 port (instead of the USB 2.0 HUB).
(2109:0812 => VIA VL812 => USB 3.0 chip at the HUB
2109:2812 => VIA => USB 2.0 chip at the HUB)
Code:[B]Bus 006[/B] Device 003: ID 125f:312a A-DATA Technology Co., Ltd. Superior S102 [B]Bus 006[/B] Device 002: ID 2109:0812 [B]Bus 006[/B] Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub [B]Bus 005[/B] Device 010: ID 0c45:8888 Microdia [B]Bus 005[/B] Device 009: ID 11c0:5500 [B]Bus 005[/B] Device 008: ID 04fc:0015 Sunplus Technology Co., Ltd ViewMate Desktop Mouse CC2201 [B]Bus 005[/B] Device 007: ID 2109:2812 [B]Bus 005[/B] Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The HDD's only works if I use the external USB 3.0 HUB with a PSU at the HUB...
Code:[B]Bus 006[/B] Device 004: ID 125f:312a A-DATA Technology Co., Ltd. Superior S102 [B]Bus 006 Device 005: ID 174c:5106 ASMedia Technology Inc. Transcend StoreJet 25M3[/B] [B]Bus 006[/B] Device 002: ID 2109:0812 [B]Bus 006[/B] Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 007: ID 0c45:8888 Microdia Bus 005 Device 003: ID 04fc:0015 Sunplus Technology Co., Ltd ViewMate Desktop Mouse CC2201 Bus 005 Device 002: ID 2109:2812 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Code:[B]Bus 006[/B] Device 004: ID 125f:312a A-DATA Technology Co., Ltd. Superior S102 [B]Bus 006 Device 006: ID 1058:1042 Western Digital Technologies, Inc. [/B] [B]Bus 006[/B] Device 002: ID 2109:0812 [B]Bus 006[/B] Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 005 Device 007: ID 0c45:8888 Microdia Bus 005 Device 003: ID 04fc:0015 Sunplus Technology Co., Ltd ViewMate Desktop Mouse CC2201 Bus 005 Device 002: ID 2109:2812 Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 002: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Sorry, I don't own USB 1.1 devicesRK3288 Devices
More than 1 HDD ...
More than 1 HDD at an external active HUB wouldn't recognize...
Code:/system/bin/sh: lsusb: not found 127|root@jaws-tvd-p1:/ # busybox lsusb busybox lsusb Bus 001 Device 002: ID 05e3:0608 Bus 001 Device 001: ID 1d6b:0002 Bus 002 Device 001: ID 1d6b:0002 Bus 003 Device 001: ID 1d6b:0001 Bus 004 Device 001: ID 1d6b:0001 Bus 005 Device 001: ID 1d6b:0002 Bus 006 Device 001: ID 1d6b:0003 Bus 001 Device 007: ID 11c0:5500 Bus 001 Device 008: ID 04fc:0015 Bus 001 Device 009: ID 0c45:8888 Bus 001 Device 003: ID 05e3:0608 [B]Bus 001 Device 004: ID 1058:1042 Bus 001 Device 005: ID 174c:5106[/B] Bus 001 Device 006: ID 1a40:0101
I tested it at all 3 ports...
EDIT
I changes the ports at the HUB
Code:Bus 001 Device 004: ID 174c:5106 Bus 001 Device 005: ID 1058:1042
eMMC/NAND performance
I tested the eMMC/NAND performance at Linux.
With dd
1. First I set the governor to 'performance'
su
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
2. For the write test I use this command
3. For the read test I use
I done the write and read 3 times
Write: 14.8 / 15.2 / 15.3 MB/s
Read: 35.3 / 35.3 / 35.2 MB/s
The writes are ok but I have to say the reads could be better...
With iozone
=> Stable tarball
make linux-arm
Code:random random kB reclen write rewrite read reread read write 51200 4 1465 1400 10787 10907 9328 [B]912[/B] 51200 512 11968 13024 31555 31996 31847 12585 51200 16384 14904 14101 38583 39999 37764 16231
Here you can compare it with the UBOX 8GB (rk3288) http://www.freaktab.com/showthread.p...l=1#post279686RK3288 Devices
Hello all,
I've bought the draco aw80 telos a few months ago and I'm very happy with it' I'm using kodi ysengaard and I had no problem but a few weeks ago the box shut itself down for no reason after a while, mostly when I'm running amovie or running an app for example sdmaid or a game emulator.
I've reset the box to factory settings, same behaviour.
I've putted the "finally v0.1" rom on an sd to boot on it but the box continues to shutdown randomly.
Can someone help me ?
Thanks a lot
Thanks a lot
Hi!
Did you noticed any abnormal heat on the box while playing your movies?
Originally posted by OlivDur View Post
Hi!
Hello OlivDur,
Not at all, the box shuts down and I have to unplug and replug the power supply to make it run again but then after a while it shuts again.
It runs for about 30 minutes and it goes down with no warning.
Hello OlivDur,
Hi!
I would advise this ROM https://yadi.sk/d/LvyEAtxuihGX2 It's the most stable I've had so far.
If you still get the reboot issue, that might be hardware problem (either box or power unit)
Good luck!
Hi!
Good luck!
Courtesy of Colin Long on YouTube comments:
"I had the same problem but i fixed it . What you have too do is open the hole box open and remove the heat sink and take the huge thermal pad off the board . Its one huge pad that covers the board and chips its an huge no no . So you have too cut the pad too fit the small chips just so it covers the chips and only the chips and then place the heat sink back on the chips. Its like three prongs that hold it down"
There are currently 2139 users online. 3 members and 2136 guests.
