Draco AW80- Android OS / Launcher / UI.... features-wishes feedback here
    Sounds like keyboard layout may need to be changed, when you use the PC shortcut does it make the navbar and status bar pop out? If so that still will not be useful since it pauses the game / causes the screenshot to not be full res.
      Originally posted by OrigiCally View Post
      Is that a launcher you are using in those pictures, in that case which one?
      Yes, it's the HpHTVex launcher. It's in the collection neatly rounded up in the post by BluesmanUK here:
        OTG at Andorid for ADB
        RK3288 Devices
        - Overview BOX (LINK !)
          What do you mean?
            What do you mean?
            I found no way that the PC is able to recognise the box while running Android (also missing 'Connect to PC' at settings) so e.g. no way to use ADB via OTG (USB) at the PC (instead of via network)...
            RK3288 Devices
              4.4 doesn't have connect to PC. In settings>storage click the 3 vertical dots in the upper right of the screen and select MTP or Media device. That is what connects you to the PC. If they are not checked then you wont be connected to the PC.
              ADB doesn't work because there is no USB port defined as an OTG port. SO no connect to PC or ADB! I will fix that soon
                Hmmm, funny funny funny, because at the 4.4.2 of the RK3288 I find it at
                setting / DEVICE -> USB / ...
                and I need to select the 'Connect to PC' if I want to use ADB via OTG (and of cause deselect it, if I want to use the port at HOST-mode for e.g. HDD and so on)...
                The other part I also find at the Storage....
                RK3288 Devices
                  a few things, some repeated probably
                  hello guys
                  a few things I am noticing
                  1/ keyboard is dodgy to say the least...
                  on all my other andoird boxes, I have had very little problem using the Logitech k400 keyboard. With this device, the keyboard sometimes does not function at all after coming out of standby, I have to reboot the device.
                  2/ no live wallpapers work, you might install them, but then when you try to use them, the system says they are not installed, even though you can choose one of them in your wallpaper selection interface.
                  3/ makes a loud cracking sound when powering off.
                  4/ no location at all... I would have thought it would get location from wifi?
                  That's all I can remember right now...
                  tx
                  Mark.
                  _________________________________________
                  Out: USB audio, HDMI
                  In: Logitech K400 keyboards
                    For me, the most dispiriting defect is the agonizing slowness of page transitions in XBMC. I have literally been able to take a meaningful cat-nap going from one page of links to the next - no matter what the add-on.
                      Has anyone tried to use the Tasker app on Draco yet? I can't seem to open the app. I've contacted the developer, and he's asked me for a bug report. I can't seem to get the system to give me a buy report.
                      My two problems.... I can't run Tasker, and I can run a bug report.
                      I'm on the 4G/32G, running Finless ROM.
                      Sent from my iPad using Tapatalk
                        you can use
                        SysLog
                        => play.google.com/store/apps/details?id=com.tortel.syslog
                        to get the log's
                        or you do it via ADB...
                        We're on a development site - at least in theory. To help out development without actually having some knowledge it's really important to know how and when to get logs. Lately more and more people in this section do grab appropriate logs, which...
                        I know how annoying it is trying to set up ADB, open a terminal, export logs to local files, copy, paste, etc just to submit a bug report or help a developer diagnose an issue. That is why I put together this little app to do all of that for...
                        RK3288 Devices
                          What do you mean by that?
                          Is xbmc interface laggy on this box beyond the playback issues?
                          I think the more I hear the less I want to buy it. At least xbmc interface and playback sound very smooth on the minix x8-h plus.
                          I am disappoint
                            Hi i have the 2gig/ 16gig
                            Seem to get skipping. On any video playpack. You yube kodi. Etc. Even sd card from camera or phone.
                            Some times the air mouse stops working after it sleeps. Have to plug it in or reattach receiver. Or rest.
                            Some times it just freezes.
                            Sent back to geekbuying. Waited 5 months. Still crap
                            I believe it is the stock rom.
