Mk 808
    Mk 808
    My stick is stuck on start up as all I see onscreen is. SMART TV
    It just stays on this for ever
    My laptop does not recognise it and if I try to put it into flashing mode by inserting a pin into the hole on top and powering up with USB cable into the OTG The blue LCD light stays on
    ANY IDEAS GUYS
    Are you using Windows 8?
      Mk 808
      No I using 7
      I now got it loaded
      But it starts ok then screen goes blank
        Did your problems start after you flashed a rom or did they just appear out of the blue?
          Mk 808
          It originally started just out of blue
            It could be that your ROM is set to run at a resolution higher than your tv supports. Finless 720p ROM has a bug where it outputs 1080p unless you switch it to 720p in settings. If you can't see the settings menu, the only way to make the change is connect to a 1080p tv to make the switch, power off and then reconnect to your 720p or 1080i TV.
